milestog
Jan 31, 2020Aspirant
RBR850 Security Flaw - no password required
Typing 192.168.1.1 to access my router does not prompt for a username or password. I do not save or cache passwords. The behaviour is the same on Chrome, IE, Firefox, and Edge. The behaviour is th...
- Feb 22, 2020
RESOLVED
With no help from NG support I have found the problem and the solution.
The two important details are, when the status led is solid white and won't go out, this means the router is still not fully setup. When in this state everything functions as expected and the user will not have any operational or functional issues, including modifying setup within the GUI.
The problems are that the white led status light stays on, and you can acccess the GUI from the WAN and LAN side.
The problem I found is during the setup process using the Orbi app, the last step takes you to a page where NG is trying to sell you added support. Previously I ignored this and closed out the app.
The solution is that you must make a selection, I chose no thanks. Once you make your selection the Orbi flashes the white status light and then the app moves to the next screen which states setup complete. White status light goes out as expected, and you are now prompted with a login pop up when trying to access the GUI using WAN or LAN.
Should someone experience this issue and are unable to resolve, please pm me and I will provide more details to assist you in correcting these two issues.
Can a moderator please mark this discussion as resolved.
Feb 07, 2020Guru - Experienced User
Any progress on this?
I've talked to others that have this system and they don't see this issue.
milestog wrote:Typing 192.168.1.1 to access my router does not prompt for a username or password. I do not save or cache passwords. The behaviour is the same on Chrome, IE, Firefox, and Edge. The behaviour is the same regrdless if I try on any compter as long as the computer is logged into my wireless network. I have confirmed on 5 different computers including computer with newly installed Windows and computers that access the network the first time. This is a major security flaw as anyone I give temporary access to can access my router. Ive, tried resetting the router, rebooting it, and
- mrwkbrdrFeb 07, 2020Star
Netgear has no idea, as they have yet to contact me. My case is still open stating awaiting next level support.
- FURRYe38Feb 08, 2020Guru - Experienced User
Did you send Blanca_O a private message? I believe she's trying to contact you. Keep in contact with Blanca.
mrwkbrdr wrote:Netgear has no idea, as they have yet to contact me. My case is still open stating awaiting next level support.
- mrwkbrdrFeb 10, 2020Star
She contacted me only to tell me they still have no idea as to the cause of the issue.
she states that my case is awaiting next level support.
frustrating that I paid $600 for a unit with a security flaw in which I am not using because of this security flaw. You would think netgear would pull out all of their resources to at least attempt to understand why you can access the GUI without being prompted to login. My internet provider assigns a fixed IP address, I can type in this IP address and access the Orbi GUI without being asked for any user name or password. This seems serious to me, but I guess netgear does not. My case has been open since January 4th. Very poor experience with netgear support and product.
