Johns_PDX
Nov 14, 2020Tutor
RBR850 slow WiFi speed
I have Fios 1 gig service but my WiFi speeds often plummet to 2 Mbps or so and for extended periods. I have anOrbi router and two satellites. Typically measuring speed with IPhone 11 within 20 feet of...
Nov 14, 2020Guru - Experienced User
You Arris modem is already a router and has wifi.
What mode is the modem working in? If router:
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Check your connection rate with the iphone with the RBR by using wifisweet spots app on the phone. My 12 Pro Max is seeing around 500-600 connected to my RBR.
- Johns_PDXNov 14, 2020Tutor
You Arris modem is already a router and has wifi. True. I've disabled its WiFi signal and am running my orbi in AP mode.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop This is what I've done.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeCheck your connection rate with the iphone with the RBR by using wifisweet spots app on the phone. My 12 Pro Max is seeing around 500-600 connected to my RBR. Currently measuring 600-700 about 8 ft from router.
I made the other adjustments you mentioned, although didn't see an option for Armor or IPv6 within orbionline.
