BigTex22
Sep 07, 2020Follower
RBR850 slow WiFi speeds
I recently purchased the Orbi Tri-band Mesh WiFi 6 System. Our current internet is via Frontier with 500/500 mbps. I turned off the wifi function on our existing Frontier router and plugged our RBR...
CrimpOn
Sep 07, 2020Guru - Experienced User
BigTex22 wrote:I recently purchased the Orbi Tri-band Mesh WiFi 6 System. Our current internet is via Frontier with 500/500 mbps. I turned off the wifi function on our existing Frontier router and plugged our RBR850 router into an existing ethernet jack in our home. I then placed its companion satellite upstairs.
At first glance, it appears (to me) that the ethernet cabling from the existing Frontier router to the wall jack is rated only for 100mb.
One way to check is to look at the Orbi web interface, Advanced Tab, and click on the blue box "Show Statistics". What does it show for the WAN interface?
Also, you may not be aware that Netgear created a separate community forum for the new AX products. People who participate in that forum probably have more experience with the new product than those of us on this forum who have the older "Original Orbi":
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
As an aside, most of us replace the previous WiFi router with the Orbi router rather than connecting the Orbi to it. There is often a problem in specific situations with what is called a "Double NAT" condition:
