umkhonto
Oct 28, 2023Aspirant
RBR850 slow wireless and ethernet port speeds
Hardware connection order: CM 2000 > RBR 850 > GS 324 gigabit switch (CAT 6 cables) Network: 1 RBS 850 satellite Neither the wireless download speeds nor ethernet download speeds come close to m...
Oct 29, 2023Guru - Experienced User
Between the RBR and GS, CAT6 UTP is Good.
Do you have IPv6 enabled or disabled on the RBR?
umkhonto
Oct 30, 2023Aspirant
RBR850 IPv6 is currently disabled. Given info below is there a setting that you recommend: Auto Detect, 6to4 Tunnel, Pass Through, Fixed, DHCP, PPPoE, Auto Config, or 6rd Tunnel?
Other info I should have included in original post.
Internet provider: xfinity Gigabit Extra
RBR850 firmware version: v7.2.6.21_5.0.20
WAN Preference: Internet Port (2.5 Gbps)
LAN setup: Router used as DHCP server
Wireless setup: 2.4 GHz and 5 GHz
- FURRYe38Oct 30, 2023Guru - Experienced User
Can try Auto for IPv6 on the RBR and see if this changes anything. Been odd issues and problems with IPv6 between Orbi systems and ISPs. Otherwise, disable it.
Id test speeds with the RBS turned OFF and two PCs connected to the back of the RBR with out the switch in the mix. Make sure your getting good speeds here. You should good speeds ethernet connected behind the RBR. With Armor, Traffic Meter and SPC disabled or right after a factory reset and setup from scratch using a web browser. Don't setup using the Orbi app.
I presume your getting good speeds with one wired PC connected directly to the modem right?
- umkhontoNov 17, 2023Aspirant
Same disappointing speed ~390-400 Mbps.- FURRYe38Nov 18, 2023Guru - Experienced User
If your getting those speeds at the modem and not connected to the Orbi system, Seems like this needs to be looked at by your ISP.
Also run a test with a different PC to compare results as well.
