umkhonto
Oct 28, 2023Aspirant
RBR850 slow wireless and ethernet port speeds
Hardware connection order: CM 2000 > RBR 850 > GS 324 gigabit switch (CAT 6 cables) Network: 1 RBS 850 satellite Neither the wireless download speeds nor ethernet download speeds come close to m...
umkhonto
Dec 27, 2023Aspirant
No success. I connected my MacBook Pro directly to the CM2000 with a CAT 6 cable. Download speeds of 90 Mbps recorded.
Dec 27, 2023Guru - Experienced User
Something either with your wired device or the CM modem:
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
