Bigtuna00
Sep 05, 2023Aspirant
RBR850 Speed Capped just below 40gbps
Preface: I have observed a lot of threads about slow speeds, but they are all way faster than what I am seeing, so I'm starting a new post. Context: had my internet service upgraded today to "gigace...
Sep 05, 2023Guru - Experienced User
What is the brand and model# of this managed switch?
Do you get to spec speeds with your wired PC connected to this switch?
Sounds like something on this switch maybe not working right or well with the Orbi RBR.
Has a reset on the RBR with doing a power OFF of the RBR and this switch for 1 minuted then back ON then complete the setup wizard on the RBR with a web browser and not enabling any Armor, Access Controls, SPC or Traffic Meter been tried?
Be sure your using a good quality LAN cable between the switch and router. CAT6 is recommended.
- Bigtuna00Sep 12, 2023Aspirant
Thanks for the reply (and sorry I didn't reply sooner, I didn't get any notifications).
I hate to say it but it may have been a fluke. I'm now getting speeds >40Mbps. I never get 100Mbps when running through the RBR850 but I have seen ~75ish. There are ~40 devices on this network so I'm sure that has some effect. No idea why I was consistently getting 38-40 every time I did a speedtest for the first couple days π
Anyway thanks for looking.
- FURRYe38Sep 12, 2023Guru - Experienced User
Next time if you do see this issue again, try this:
Power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Glad it's working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. π‘
