ottopaulsen
Nov 02, 2021Tutor
RBR850 still losing internet connection several times a week
All info on previously closed case. I am still loosing internet connection several times every week. The thing is that it ALWAYS helps to reboot the router, or even logging in and running Intern...
ottopaulsen
Nov 05, 2021Tutor
Ok, thanks. Guess I have to try this.
I have 32 devices with fixed IP, based on mac address. Is there a way to export and import them, so I don't have to enter one by one through that tedious interface?
Otto
Nov 05, 2021Guru - Experienced User
Can try loading the config file and see, if problem continues, i'd try reset and do a test with out loading the backup from file.
Otto
- ottopaulsenNov 08, 2021Tutor
Now it is done, so let's wait and see.
I entered everything manually.
Please keep this open until I have tested at least a month or two.
- FURRYe38Nov 08, 2021Guru - Experienced User
- ottopaulsenJan 29, 2022Tutor
So this lasted a couple of months. It worked much better in the beginning. I guess I had to restart 1-2 times during the first 6-8 weeks. Now I am back where I started, losing internet several times a week the last couple of weeks. As usual, a restart of the router solved the problem, but having to do this almost daily is not acceptable.
I am beginning to want to return the hardware. Are these problems reasons enough?
- FURRYe38Jan 29, 2022Guru - Experienced User
I'd review this since it's been a while since you first posted:
