russellmoran99
Nov 10, 2021Luminary
RBR850 System - Satellite Options
I am replacing my old RBR50 system with an RBR850 to improve performance. I have 2 satellites and need a 3rd smaller one. I have a few of the RBS50s and a wall satellite. Will either of those work...
- Nov 10, 2021
IT was posted in the recent FW upate for the 7 series:
The 8 series has not seen a v5.something update yet, which I'm not sure if it will get the same 3 series RBS support though I presume it might. Hard to day. If you want some additional signals, either find another RBS8 series or try the EAX80.
russellmoran99
Do you know where I can find that information? I want to verify that it will work so I am not wasting my time on it. Thank you for all the help.
Nov 10, 2021Guru - Experienced User
