bhopal21
Dec 09, 2023Aspirant
RBR850 system with 4 satellites—New modem
I have been advised by Xfinity to replace my current Arris SB8200 modem with the Arris S33 modem due to an increase in the speed of my service. I am not adept at all with new technology and would...
- Dec 09, 2023
After new modem is online and working, Power cycle the modem OFF along with the RBR850 for 1 minute, connect the RBR to the new modem and power ON the modem. After 30 seconds after the modem has been turned on. Power ON the RBR. If all is good on the modem, the RBRs front LED should blink WHITE then front LED should turn OFF. Meaning good connection and internet service from the modem.
bhopal21
Thank you so much for your helpful response!👍
Michael
Dec 09, 2023Guru - Experienced User
Let us know how it turns out.
I'm getting ready to do same thing. Put new modem online. 😁
- bhopal21Dec 12, 2023Aspirant
Worked perfectly! Thanks to you it was a very easy setup.
Took Xfinity around 11 minutes to recognize the new modem and around 6 min for Orbi to connect.
830Mbps throughout the house now.
Thanks again,
Michael
- FURRYe38Dec 12, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
