rschein
Feb 06, 2022Aspirant
RBR850 turn off 5 ghz so 2.4 connects
I have an IOT light that needs to connect via 2.4 ghz to the configuring device (tablet or phone). How do I disable 5 ghz so only 2.4 works on devices temporarily.
- Feb 07, 2022
Punted. Found Old Router Set It Up With Only 2.4 same SSID And Pw.
Feb 07, 2022Guru - Experienced User
You can't disable the wifi radios on Orbi. So you might want to also change the power output of the 5Ghz radio to 25%. Turn OFF the RBS, Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- rscheinFeb 07, 2022Aspirant
- FURRYe38Feb 07, 2022Guru - Experienced User
Backup configuration to file:
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
