filmnikon
Jul 21, 2022Aspirant
RBR850 Unable to set custom primary and secondary DNS servers
I recently noticed that my Orbi home network was no longer using "Open DNS" DNS servers as I had configured it a few years back. I am not sure on when this changed. To troubleshoot, I went into the...
- Jul 28, 2022
Finally solved it. Leaving some paper trail for others:
- There are a few reasons why DNS servers will change, here is some information on this: DNS Servers Keep Changing Away from OpenDNS Automatically – OpenDNS.
- Turning Parental Controls on or off has no impact on the ability to change the DNS servers.
- How to change the DNS servers if they are "grayed out": factory reset the router without being plugged into internet. You will have to proceed even past scary warnings that you should not set up the router without being connected to the internet. If you are configuring your own DNS settings then you probably know what you are doing, however. The DNS server settings will be configurable after factor reset. Once you have configured them, you can now connect internet (eg, from your cable modem). You will find that the DNS servers are "locked" / grayed out once again, but at least they will be your chosen DNS servers.
Jul 22, 2022Guru - Experienced User
Is Armor or SPC enabled? If so, disable these and try again?
filmnikon wrote:
I recently noticed that my Orbi home network was no longer using "Open DNS" DNS servers as I had configured it a few years back. I am not sure on when this changed. To troubleshoot, I went into the Advanced -> Internet Setup page on routerlogin.com and noticed that the Domain Name Server (DNS) Addresses section is grayed out, with "Get Automatically from ISP" checked. I am unable to select "Use These DNS Servers".
Does anyone have any idea how to configure overrides for primary and secondary DNS servers? Earlier today I upgraded manually to the latest firmware and performed factory resets on all my Orbi devices, just to see if it helped, but the problem remains (grayed out option). Any thoughts?
I have provided a screenshot of the relevant section below.
Thank you!
Model: RBR850 with 2 satellites
Firmware: V4.6.8.5_2.1.9
Environment: Comcast cable
Cable Modem: Arris SB8200
filmnikon
Jul 26, 2022Aspirant
How does one disable SPC?
- FURRYe38Jul 26, 2022Guru - Experienced User
After you disable both Armor and SPC and the changes get applied, I would power OFF the RBR for 15 seconds then back ON. Check the DNS settings on the web page. Should be able to change them.
As last resort, you may need to factory reset and setup from scratch using a wired PC and web browser, after setup wizard completes, go in and make the DNS changes then.
- filmnikonJul 27, 2022Aspirant
I disabled parental controls, rebooted, and this did not open up the ability to edit DNS settings.
Factory reset also did not open up the ability to edit DNS settings.
- FURRYe38Jul 27, 2022Guru - Experienced User
When you factory reset the RBR, did you use a PC and web browser to setup the RBR. Also during setup did you have the RBR disconnected from the ISP modem?
