Electric1
Nov 19, 2022Tutor
RBR850 v RBR960
Hello All, Is there much difference between the RBR960 and the RBR850 for those that have tried and used both? I have the RBR850 with 3 satellites now, and considering moving to the RBR960. My ...
- Nov 21, 2022
Not sure what I'd recommend for business class stuff as I mainly focus on the consumer side. I'd post in the business forum and ask for recommendations. Go over your complete setup, your home size and whats its made from. Those are kind of key
Electric1
Nov 19, 2022Tutor
Thanks for the reply! Which business equipment would you suggest? The business versions of the 850 appeared to be the same equipment with different software so I didn’t bother initially. But having seen the state of the firmware issue in here maybe that was a mistake.
I currently have this ONT with the 10gbps port enabled.
https://www.adtran.com/622v.html
Nov 21, 2022Guru - Experienced User
