hkoppp
May 09, 2021Star
RBR850 V3.2.18.1_1.4.14 latest firmware CONSTANT DISCONNECTIONS
Guys, ever since latest firmware update on my orbi router im having constantly daily disocnnections at least 5 times per day never happened on an older firmware version i cant use my internet like ...
CrimpOn
May 10, 2021Guru - Experienced User
hkoppp wrote:Guys, ever since latest firmware update on my orbi router im having constantly daily disocnnections at least 5 times per day
i want to downgrade to a stable version but it keeps reverting back to latest version firmware
I agree that most of us who participate in this Orbi forum have zero experience with the new "AX" product line.
How many firmware versions back have you gone?
After a manual firmware update (to an older version), how long is it before the Orbi goes back to v3.2.18.1 by itself?
While waiting for a solution, could you give more description of "what happens" many times a day?
- Does the actual internet connection disappear from the Orbi web interface?
- Does the Orbi WiFi signal drop?
- Does it appear that the DNS function stops working?
i.e. you can 'ping' an IP address, such as 1.1.1.1 but cannot ping by URL one.one.one.one? - Are all devices in the network affected the same way?
- What is the Orbi connected to? (ordinary modem? combination modem/router?)
hkoppp
May 10, 2021Star
yeah says waiting connection error
wifi drops on all laptops
dns doesnt work as wifi is disconnected
all device affected
orbi connected to modem
- CrimpOnMay 10, 2021Guru - Experienced User
hkoppp wrote:yeah says waiting connection error
all device affected
"waiting connection" is a message on the laptop?
Can any of the laptops be connected to the Orbi with an ethernet cable?
Are there any "Internet of Things" (IoT) devices connected to the Orbi that can be accessed from a cell phone app. My thermostat and smart plugs, for example, can be reached with the app when I am not even at home.
The power LED on the back of the router is still green, correct?
When this happens, do things recover if the reset button is pressed briefly (one second) or the power is cycled?
- hkopppMay 10, 2021Star
waiting connection error is on the orbi router interface
router is pink when this happens
yes i have laptops connected on cat5 hardwired loss of internet on all devices
