hkoppp
May 10, 2021Star
RBR850 V3.2.18.1_1.4.14 latest firmware CONSTANT DISCONNECTIONS
Guys, ever since latest firmware update on my orbi router im having constantly daily disocnnections at least 5 times per day never happened on an older firmware version i cant use my internet like ...
May 10, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
- Does the actual internet connection disappear from the Orbi web interface?
- Does the Orbi WiFi signal drop?
- Does it appear that the DNS function stops working?
i.e. you can 'ping' an IP address, such as 1.1.1.1 but cannot ping by URL one.one.one.one? - Are all devices in the network affected the same way?
is Traffic Meter or Armor enabled on the RBR?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
