AmCovi2021
Sep 23, 2021Follower
RBR850 v4.6.3.16_2.0.51 constant disconnect and reconnect
Woke up to a solid magenta light on my Orbi. I updated the firmware and have restarted it twice. The orbi connects to the internet and I have a good WiFi signal then it drops back off. My wired co...
RC-RC
Nov 16, 2021Aspirant
how did you fix the problem? i still have the same problem. I have tride a factory reset, restart etc. but nothing is working?
- RC-RCNov 16, 2021Aspirant
netgear when do you release a firmware update where the problem is fixed? timelins please!
Setup: 1 x RBR850 -> 2 x wired RBS850
- FURRYe38Nov 16, 2021Guru - Experienced User
FYI, @ netgear hasn't log into there profile account since 2015 so probably no use in tagging them. If you want to tag someone, try a forum moderator like @ blanca_o or @ darrenM
What I did to get v4.6.3.16 working on 8 series:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2155645/highlight/true#M22357
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2154700/highlight/true#M22256New Orbi v4 Factory Reset:
You may need to factory reset the system and power the system OFF as well.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M21579
