Intoxicating
Apr 27, 2022Star
RBR850 V4.6.8.2
My RBR850 had a firmware update message so pressed update all, only the router updated and the satellite is saying no new version available.
Netgear product support website makes no mention of the V4.6.8.2 so unable to manually update the satellite.
Any info on what this firmware is supposed to fix?
Thanks
Firmware Version: V4.6.8.2_2.1.9
dumaos: v3.0.410
seal: v2.1.5.37-0
seal_services: v2.1.5.12-0
armor-bd: v2.2.100.3
spc-circle: v3.25.0.2
CPU Load: 15.54%
Memory Usage(Used/Total): 316 MB/874 MB
System Uptime: 0 days 00:09:26
Maybe similar to what the 7 series released with however won't know for sure until NG posts it officially for the 8 series:
Release notes,
https://kb.netgear.com/000064879/RBR850-RBS850-Firmware-Version-4-6-8-2
New Features:
- Supports Smart Parental Control (SPC)
- Removes the remote management feature from the router web interface (if disabled at time of update) to improve router security.
- DHCP Option 60&61 support for ISP internet & IPTV connectivity
Enhancements:
- Singapore password requirement enhancement
Security Fixes:
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Bug Fixes:
- Fixes Armor activation issue
- Fixes SPC activation issue
- Fixes DNS timeout issue
- Fixes the issue where a phantom satellite appears in device list
- Fixes the issue where satellite LED ring will randomly light solid blue
- Fixes orbilogin.net access issue when DoH (DNS over HTTPS) is enabled
- Various other bug fixes
Download Link:
RBR850: https://www.downloads.netgear.com/files/GDC/RBK852/RBR850-V4.6.8.2.zip
RBS850: https://www.downloads.netgear.com/files/GDC/RBK852/RBS850-V4.6.8.2.zip
Please post any new FW experiences in this thread please:
Thank you.
