giovannivl
Feb 26, 2022Follower
RBR850 VLAN Settings No Activate after Reset
Hi All,
I'm using FW V4.6.3.16_2.0.51 on my Orbi RBR850, my setup use PPPoE to my ONT, but i need to set my VLAN to 300 in "VLAN / Bridge Settings" menu to get interner connection.
It's works as expected, but after a manual reset or any type of reset, on "VLAN / Bridge Settings" the check of "Enable VLAN / Bridge Setup" start unchecked, so, i need to check again to connect.
Am I missing somenthing in my configuration for after reset de VLAN configurations starts checked?, Thanks for your support!!
1 Reply
Many times I have become distracted and forgot to click the "Apply" button at the top of the screen. (Not on this feature because Spectrum does not use it.)
