nickt3
Sep 17, 2024Guide
RBR850 VPN stopping traffic for Appen.com
Firmware Version V7.2.6.31_5.0.24 I have started doing some gig work for Appen.com and I am continually getting a warning: when I attempt to start a job. I get this also on my laptop, on ...
Sep 17, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
CrimpOn
By any chance is Bitdefender Armor enabled on this system?
Scroll down this page:
https://www.netgear.com/home/services/armor/
