rrozenthal
Oct 14, 2021Aspirant
RBR850 w/3. Satellites not working properly
Hi, Using Orbi at home for almost a year now. This is the third mesh system I installed in this home and the first that works as close to optimal as one can hope. 1) after installing the router and ...
Oct 14, 2021Guru - Experienced User
Has a power off for 5 minutes then back ON with the ISP modem and Orbi system been performed since last update?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
You have to use Orbi app to enable anywhere access. Remote access is no longer seen on the RBRs web page.
rrozenthal
Thank you for quickly picking this up!
I rebooted the router (including my Fios Gigabit ISP) multiple times. Deleted and reinstalled the IOS app. Tried accessing from multiple devices (iPad/iPhone)
With no luck. The error (attached) shows up as soon as I click settings—>anywhere access.
Different error when clicking the router directly.
- FURRYe38Oct 14, 2021Guru - Experienced User
Try a full power OFF of the system and ISP ONT for 5 minute. This means pull the power adapters from the wall sockets, wait, then plug back in.
Possible problem with the Orbi app, I would post about over in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
You could try a full on reset on the RBR and setup from scratch with a wired PC and web browser. Once setup, log in to the RBR with the Orbi app and see if you can enable anywhere access.
or open a support ticket and talk to NG support about the app issue:
