rrozenthal
Oct 14, 2021Aspirant
RBR850 w/3. Satellites not working properly
Hi, Using Orbi at home for almost a year now. This is the third mesh system I installed in this home and the first that works as close to optimal as one can hope. 1) after installing the router and ...
Oct 14, 2021Guru - Experienced User
Has a power off for 5 minutes then back ON with the ISP modem and Orbi system been performed since last update?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
You have to use Orbi app to enable anywhere access. Remote access is no longer seen on the RBRs web page.
rrozenthal
Also, found that the router it self is not accessible?
