rrozenthal
Oct 14, 2021Aspirant
RBR850 w/3. Satellites not working properly
Hi, Using Orbi at home for almost a year now. This is the third mesh system I installed in this home and the first that works as close to optimal as one can hope. 1) after installing the router and ...
rrozenthal
Thank you for quickly picking this up!
I rebooted the router (including my Fios Gigabit ISP) multiple times. Deleted and reinstalled the IOS app. Tried accessing from multiple devices (iPad/iPhone)
With no luck. The error (attached) shows up as soon as I click settings—>anywhere access.
Different error when clicking the router directly.
Oct 14, 2021Guru - Experienced User
Try a full power OFF of the system and ISP ONT for 5 minute. This means pull the power adapters from the wall sockets, wait, then plug back in.
Possible problem with the Orbi app, I would post about over in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
You could try a full on reset on the RBR and setup from scratch with a wired PC and web browser. Once setup, log in to the RBR with the Orbi app and see if you can enable anywhere access.
or open a support ticket and talk to NG support about the app issue:
