Enuffznuff21
Feb 01, 2023Follower
Rbr850 wan port only 1000m/full
Had Comcast 1.2gbs for awhile. Speeds always stayed at 900ish. Assumed it was Xfinity issue. Upgraded to Comcast 2gbs with their router. Still getting 850-900 speeds but my upload tripled. Did some d...
Feb 01, 2023Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Be sure the ISP modem or ONT supports 2.5Gb WAN port speeds on it's WAN port.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
The RBR auto detects connection rates so if all is good, the WAN port should see 2.5Gb.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
