jeremypea
Jul 26, 2023Tutor
RBR850 WAN stuck on 100m/full
I have owned this router for a while now and for the most part, have not had any issues with it. Lately I've noticed some lagging on certain devices and after doing a speed test on multiple devices,...
Jul 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- jeremypeaJul 27, 2023TutorI did all of this…..multiple times last night.
Still no luck!!
