jeremypea
Jul 26, 2023Tutor
RBR850 WAN stuck on 100m/full
I have owned this router for a while now and for the most part, have not had any issues with it. Lately I've noticed some lagging on certain devices and after doing a speed test on multiple devices,...
Jul 27, 2023Guru - Experienced User
You tried directly connecting to the modem?
and it connected at gigabit speeds?
Is the modem right next to the router? Or is it in a different room?
jeremypea
Jul 27, 2023Tutor
Correct!!
Different room.
Different room.
- plemansJul 27, 2023Guru - Experienced User
for testing, try moving the router right next to the modem and just use 1 cable to connect modem---router.
to frequently I see wall jacks that have a sketchy press down or connection that causes issues.
- jeremypeaJul 27, 2023TutorI did that last night as well……tested 6 different cables in all just to make sure it wasn’t a cable issue.
jeremypea wrote:
I did that last night as well……tested 6 different cables in all just to make sure it wasn’t a cable issue.With it in the same room as the router? so its not going through the wall ports?
You can try a lan/wan loopback test to see if the ports are connecting at gigabit on the router.
