Nathan810
Jan 17, 2024Aspirant
RBR850 WiFi dropping off
Hi all could any help me please I have the RBR850 router and 3 satellites each satellite is spaced correctly I live in a bungalow my network provider is BT in the UK running 900mbps. When running a sp...
Nathan810
Hi thank you for your fast response I'm afraid a lot of your response is over my head I just wise we had someone like yourself I could pay to come and go through my wilf to set it all up correctly for me but we don't lol. I'll try and answer the best I can the satellites are about 40 feet apart .
The overall area about 4,179sq feet
Current firmware version V7.2.6.21
Not sure what Mfr is model of ONT is Nokia-ONT
Model number G-010G-Q LAN
Cable are VOSGA Outdoor Cat 7 Ethernet Cable S/FTP - 600 MHZ -Cat7
I'm not sure about channels that's over my head I'm afraid, for other WiFi networks my phone only picks up mine my neighbours are 60 feet away. Thank you
Jan 19, 2024Guru - Experienced User
Maybe bring the RBS closer to the RBR? Say 30-35 feet?
Does the front LED turn ON PINK when this happens on the RBR?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 channel on 5Ghz.
