unscathed
May 17, 2022Aspirant
RBR850 Wifi Drops - Hardwire fine.
I have the Orbii RBR850 system with the Router and 2 satellites and I have been having intermittent problems with WIFI drop outs for a few months now. I use ATT Fiber 1Gup/1Gdown. Current Firmware...
May 17, 2022Guru - Experienced User
Does the front LED turn on WHITE or PINK when this happens?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
CAT5 isn't recommended as its only rated for 100Mpbs. CAT6 is recommended and support 1000mpbs rates.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Traffic Meter and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
unscathed
Sorry.. should of been specific.. Cat5e
Category 5e-1 Gigabit/sec-100 meters (328 feet)
Category 6- 3 Gigabit/sec-100 meters (328 feet)
Home is 3300 Sqft.
I will check the other things you mentioned.
