unscathed
May 17, 2022Aspirant
RBR850 Wifi Drops - Hardwire fine.
I have the Orbii RBR850 system with the Router and 2 satellites and I have been having intermittent problems with WIFI drop outs for a few months now. I use ATT Fiber 1Gup/1Gdown. Current Firmware...
unscathed
May 21, 2022Aspirant
2800 Square foot..
Gateway is a PACE 5268AC
Orbi Router is in AP Mode (most functionality is off) and still had this issue in router mode.
Firmware is V4.6.8.2
5G on Auto and I have tried 48
2.4G I have done 1,6,11
There are other networks nearby, but mine is the most powerful in the hood.
May 21, 2022Guru - Experienced User
What mode is the modem working in? Router or Bridge mode? This already has a built in router and wifi.
- unscathedMay 25, 2022Aspirant
If I only have the ORBI setup as an AP... it shouldn't matter what mode the router is in. This would only be relevant if the Orbi was routing itself correct?
- FURRYe38May 25, 2022Guru - Experienced User
Yes...does matter about the ISP modem.
If all the ORBI is doing is acting as an Access Point, and the Gatway-Router is still functioning as a Router with no wifi, why would I bridge it?
You would Bridge it assuming Orbi was going to do all the work, but it is not. What am I missing here?
