russellmoran99
Feb 23, 2022Luminary
RBR850 Wired Backhaul keeps switching from Wired to Wireless
Howdy y’all. I have an Orbi RBR850 with 2 wired RBS850 and 1 wireless RBS750 satellites. All satellites work but one of them seems to randomly switch from wired to wireless mode randomly. I’m assumin...
Feb 23, 2022Guru - Experienced User
What is the model# of the ethernet switch in the configuration?
What Cat# cables are you using? CAT6 is recommended.
Only a couple of factors that would cause this, some switches can be problematic. Some Green Ethernet featured switches, cable inbetween the RBR and RBS is not good, connections are bad on the cables or there maybe a bad patch panel in the mix.
russellmoran99
Switch - Netgear GS108 Gigabit Switch
Cable - Cat6E
No other switch/patch panel in between the connection to this specific saltellite. I can double check my ends and make sure they're good.
