russellmoran99
Feb 23, 2022Luminary
RBR850 Wired Backhaul keeps switching from Wired to Wireless
Howdy y’all. I have an Orbi RBR850 with 2 wired RBS850 and 1 wireless RBS750 satellites. All satellites work but one of them seems to randomly switch from wired to wireless mode randomly. I’m assumin...
Feb 23, 2022Guru - Experienced User
What is the model# of the ethernet switch in the configuration?
What Cat# cables are you using? CAT6 is recommended.
Only a couple of factors that would cause this, some switches can be problematic. Some Green Ethernet featured switches, cable inbetween the RBR and RBS is not good, connections are bad on the cables or there maybe a bad patch panel in the mix.
russellmoran99
I doublechecked and ran a tester on my ends, they seem to be Good to Go.
I went ahead and removed the switch from the equation and using the ethernet from the RBR850 direct to the RBS850 in question. We'll see what happens.
- FURRYe38Feb 23, 2022Guru - Experienced User
- cloudwaveApr 02, 2022Aspirant
I'm having the same issue. Good cable. Pfsense logs showing my rbr850 changing its mac ever few seconds. I think its causing massive problems on my network sporadicaly. Anyone find a solution? I have the RBR850 plugged in to GB 24port switch and pfsense plugged into same switch. The satelite is wired to the first port in the RBR850 as I couldn't get the wired connection to work through the switch it kept switch back and forth to the wireless then wired backhaul.
Thanks!
- russellmoran99Apr 02, 2022LuminaryMine was absolutely the cable. I thought it was a good cable, but it wasn’t. I would replace the ends or the entire cable.
