Diamonds
Nov 11, 2021Aspirant
RBR850 with 2 satellites - looking to extend to a separate building
Hi, I have an ORBI RBR850 with 2 satellites. I want to add wifi to a separate building next to the main house. I have ethernet connection to the building. Do in need to use another 850 satelli...
Diamonds
Nov 12, 2021Aspirant
Thanks for your reply and please forgive my ignorance....
I don't necessarily need it to be in the mesh just that there is decent wifi.
My setup is feed cable into house, into service provider router that's on bridge mode, into RBR850, into switch. From there there's ethernet cabling to all rooms including the external house.
I have 2 RBS850 satellites and the reach doesn't get to the external house very well at all.
From your reply I can just get any wifi router hardwired in the external house, the fact that it ultimately goes through the Orbi doesn't matter - correct?
When you're in the external house it'll pick up that wifi and when you're in the main house it'll pick up the Orbi mesh network - correct?
thnaks again!
michaelkenward
Nov 12, 2021Guru - Experienced User
That should work. The connection from your external building is not involved in the wifi from the Orbi.
Have you checked that the LAN connection from the Orbi to the external building is OK?
