rimasidd
Jun 16, 2021Tutor
RBR850 with RBS850 Satellites (4)
Hello, I have RBR850 and (4) RBS850 .. 6500 Sq ft house ATT -1 Gig fiber into the house I am not using the router provided by ATT, I have created a bridge and use the Orbi as router. The 1 Gig ...
Jun 27, 2021Guru - Experienced User
Make sure the ISP modems wifi is fully disabled if the modem has wifi.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
rimasidd
Jun 28, 2021Tutor
the fimrware is 3.2.18.1
I have the Large house layout per the diagram.. The router is on the second floor ( since that where my home wiring is )
the satellites are in 3 corners of the house..
- FURRYe38Jun 28, 2021Guru - Experienced User
Didn't see any diagram attached to your post...
- rimasiddJun 28, 2021Tutor
its a 2 story home (8000 Sq ft )
2 nd story
top right closets to home entrance - router / att modem
top right furthest from home entrance - back of house - (Sat 1)
Top left furthest from Router- back of the house ( Sat 2 )
sat 1 and sat 2 ( extreme right / left back side of the house)
first floor
back right Sat 3
front left Sat 4
A layout or drawing of where the system is placed would be more helpful so we can see where there located with in the home.
