Kanguru
Apr 15, 2023Aspirant
RBR850 with RBSE960
My main ORBI router is the 850 model with another 850 Satellite. I have another Satellite RBSE960 and I was able to connect it to the main router as another Satellite. I'm able to connect to it and...
Kanguru
The connection between the 960 and 850 is via wi-fi, I just added a satellite and it worked.
Looking at the 850 panel I see two satellites
CrimpOn
Apr 15, 2023Guru - Experienced User
Thanks for the screen shot. From my perspective, it appears that Netgear's compatibility information deserves another footnote.
(who knows, maybe the 850 satellite is also 'compatible' with the 960 router as well? - except for the obvious feature differences.)
- KanguruApr 15, 2023Aspirant
The only issue I have is that I cannot update the SSID of the 960 to be the same as the 850
- FURRYe38Apr 16, 2023Guru - Experienced User
What FW do you have on the 8 and 9 series?
Possible that the 9 series is not compatible on the 8 series system.
- KanguruApr 16, 2023Aspirant
Latest version on both.
I noticed that the 2.4Ghz on the 960 Sat received the same SSID as my main router but not the 5Ghz or 6Ghz, both stayed ORBI80
