Kanguru
Apr 15, 2023Aspirant
RBR850 with RBSE960
My main ORBI router is the 850 model with another 850 Satellite. I have another Satellite RBSE960 and I was able to connect it to the main router as another Satellite. I'm able to connect to it and...
Apr 16, 2023Guru - Experienced User
There actual version please...
Kanguru
Apr 16, 2023Aspirant
RBR850 V4.6.14.3_2.3.12
RBSE960 6.3.7.10
- FURRYe38Apr 16, 2023Guru - Experienced User
From what I know, NG hasn't tested compatibility between the Orbi AX series and from what they posted on there support page in regards to this seems to make it NG intended support that they are not compatible. So users may or may not get RBS fully working between the models.
FW versions is far appart as well so would be another factor as well.
You may want to return the 9 series and find a 7 or 8 series RBS that is compatible.
- KanguruApr 16, 2023Aspirant
Thanks, I will try to sell it.
