miller1975
Sep 28, 2021Tutor
RBR850 wont connect to satellite in AP mode
I have an RBR850 & RBS850 configured in AP mode and I am having some issue When I check for new firmware it tells me there is no internet access so I manually upgrade (when I remember) I have...
daanjj
Oct 01, 2021Aspirant
The advice here does not work for me. I blocked these 2 URL's on my RBR850 but the router and satellite are still able to check for updates. So I assume they can also download and install updates.
Does anybody have advice for me how to block these checks so I can effectively disable auto-update?
Oct 02, 2021Guru - Experienced User
You can't block those URLs ON the RBR. you have to use a different router upstream from the RBR to block URLs.
IF you don't have a upstream router from the RBR, the you have to downgrade to v10 on the RBS and RBR and follow this on the RBR:
