SJohns
May 17, 2022Aspirant
RBR850 working fine, but can’t access admin panel
My Orbi system (RBR850 + 3x RBS850) is working as well as ever, but I can’t access the admin controls in the app, via orbilogin.com or orbilogin.net or direct to the IP address assigned by my router ...
- Jun 03, 2022
Firmware update to V4.6.8.2 was the fix apparently.
May 17, 2022Guru - Experienced User
Was your system updated recently?
NG is aware of this and is working on a patch to send out to those who are effected:
I recommend you contact NG support and ask about this patch if you need access. If not, you can wait for this to come out, don't know when though, or you can factory reset the RBR and setup from scratch which works for some.
- SJohnsMay 17, 2022Aspirant
Thanks for this. I did a manual upload of firmware version 4.6.3.16 (I think) about a year ago when trying to troubleshoot another issue (compatibility with set top boxes for streaming app) and it has been running happily since.
I’ll try the procedure in what you sent when I’m feeling brave.
- FURRYe38May 17, 2022Guru - Experienced User
Hope NG will fix this for you in mean time. Can reach out to a forum moderator to see if they can help on this.
- SJohnsJun 03, 2022AspirantAnd it miraculously fixed itself today. Still haven’t tried logging into the web console, but the app now works on my iPhone. Thanks NG?
