SJohns
May 17, 2022Aspirant
RBR850 working fine, but can’t access admin panel
My Orbi system (RBR850 + 3x RBS850) is working as well as ever, but I can’t access the admin controls in the app, via orbilogin.com or orbilogin.net or direct to the IP address assigned by my router ...
- Jun 03, 2022
Firmware update to V4.6.8.2 was the fix apparently.
May 17, 2022Guru - Experienced User
Hope NG will fix this for you in mean time. Can reach out to a forum moderator to see if they can help on this.
SJohns
Jun 03, 2022Aspirant
And it miraculously fixed itself today. Still haven’t tried logging into the web console, but the app now works on my iPhone. Thanks NG?
- FURRYe38Jun 03, 2022Guru - Experienced User
Try the RBRs web page. Mines working.
- SJohnsJun 03, 2022Aspirant
It worked.
Good to hear. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
