SJohns
May 17, 2022Aspirant
RBR850 working fine, but can’t access admin panel
My Orbi system (RBR850 + 3x RBS850) is working as well as ever, but I can’t access the admin controls in the app, via orbilogin.com or orbilogin.net or direct to the IP address assigned by my router ...
- Jun 03, 2022
Firmware update to V4.6.8.2 was the fix apparently.
SJohns
Jun 03, 2022Aspirant
It worked.
Jun 03, 2022Guru - Experienced User
Good to hear. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
