gwoit
Mar 25, 2024Aspirant
RBR850
I have to replace my modem with a new unit. The modem is supplied by Windstream. How do I connect it to my orbi router. I assume all other connections will remain the same
Mar 25, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to check out the Orbi Quick Installation Guide online as well.
Contact the ISP for additional help and support information regarding there equipment.
gwoit
thank you for the reply. I was also wondering if the orbi will recognize the new modem once powered up in the sequence you have provided
thank you again
- FURRYe38Mar 25, 2024Guru - Experienced User
