gwoit
Mar 25, 2024Aspirant
RBR850
I have to replace my modem with a new unit. The modem is supplied by Windstream. How do I connect it to my orbi router. I assume all other connections will remain the same
gwoit
thank you for the reply. I was also wondering if the orbi will recognize the new modem once powered up in the sequence you have provided
thank you again
Mar 25, 2024Guru - Experienced User
