gwoit
Mar 25, 2024Aspirant
RBR850
I have to replace my modem with a new unit. The modem is supplied by Windstream. How do I connect it to my orbi router. I assume all other connections will remain the same
Mar 25, 2024Guru - Experienced User
Good. Hopefully that's all that's needed.
I would have the ISP help you disable all Wi-Fi radios on the ISP Modem since your going to be using the 850 series for your main Wi-Fi system. Having two Wi-Fi systems can cause interference problems.
