ericcoffey23
Jul 13, 2021Follower
RBR850/AX6000 issues with smart devices - 5ghz?
I have had this setup (main + 3 satellites) for ~3 months and overall it has worked well. In the last few days though I have 3 different smart devices (LG Washing Machine, Nest Protect Smoke Alarm & ...
Jul 13, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What are you current CTS values? under Advanced Tab/Advanced Settings/Wireless Settings
