Rhyft
Jul 12, 2022Aspirant
(RBR850/RBS850) - Wifi constantly dropping from all devices
Any update to this? I've had the exact same issue you described (regularly experiencing all devices dropping wifi connection from satellite but devices connected to the satellite via hardwire maintai...
Jul 12, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Rhyft
Firmware: V4.6.8.5 on both (manually updated, downloaded the RBR and RBS latest versions from Netgear support site). Issue was present before and after update.
Modem: Moto MB8600
Home size: 3800 sq ft
Distance: >30 ft but connected via hardwire. Connection = Modem > RBR > NG GS116NA unmanaged switch > RBS
Channels: Auto for 2.4, tried all available channels for 5 GHz but no change has resulted in a fix.
Neighbors: No neighbors within ~400 ft.
- FURRYe38Jul 13, 2022Guru - Experienced User
Set manual channel 1 and 40
Set CTS to 2347
Turn down the power from 100% to 50% on the RBR.
What CAT# lan cable is being used between the RBR, Switch and RBS?
- RhyftJul 13, 2022Aspirant
Done - I'll see if it continues to happen.
RBR <> switch = cat6
switch <> RBS = cat6 home wiring and cat7 from the in-wall port to RBS
- RhyftJul 13, 2022AspirantIt has continued to randomly drop, even with the recommended changes above. As before, devices that are hardwired to the satellite maintain their connection.
