Xmk123
Aug 30, 2021Tutor
RBR850/RBS850 4.6.3.9 Firmware problem
RBR850 in AP mode After updating to 4.6.3.9 (rbr850 and rbs850 s) lost CONNECTION (wireless) to my two satellites (RBS850). Tried wired (backbone), works. Switched to router mode all fine (wireless a...
- Aug 30, 2021And xcelebric on this forum
Xmk123
Aug 30, 2021Tutor
As for the auto update, my rbr850 is on AP mode behind a pfsense router and I have blocked internet access to the rbr850
Aug 30, 2021Guru - Experienced User
Good to hear.
I'll check my system out today and see if this happens on mine. Now that I can configure the system from being in router mode. :smileywink:
Enjoy.
