Xmk123
Aug 30, 2021Tutor
RBR850/RBS850 4.6.3.9 Firmware problem
RBR850 in AP mode After updating to 4.6.3.9 (rbr850 and rbs850 s) lost CONNECTION (wireless) to my two satellites (RBS850). Tried wired (backbone), works. Switched to router mode all fine (wireless a...
- Aug 30, 2021And xcelebric on this forum
Sep 01, 2021Guru - Experienced User
So factory reset the system today. Bad behavoir seen on the RBS and syncing while in router mode. I could not get the RBR into AP mode as it would revert back to the main model section screen on the browser after selecting Ok on the information popup window. Tried two different computers and browsers. Not good. Sent to NG for review. If nothing happens, I'll revert to v3. :smileyembarrassed:
Sep 02, 2021Guru - Experienced User
So after yesterdays failure of configuring AP mode after doing a factory reset, I had unplugged the entire system and left it alone for 24 hours. I came back today and the request of NG to collect logs on what I had seen yesterday. Well, today, after pluging in the RBR and RBS, the RBS synced correctly to the RBR in router mode. Yesterday, had seen 1 RBS connect at 2.4Ghz and the other said it was "out of sync". Today, both synced at 5Ghz and status remained GOOD.Yesterday the web took me back to the Router/AP mode page and could never get the RBR to apply the AP node, Today I attempted to configure AP mode on the RBR and after selecting OK, the web page reported it was rebooting the router. Several minutes later the RBR was in AP mode, then the RBS began to blink WHITE then after than turned BLUE and then OFF. The RBS have been so far working for past 4 hours and I have yet to see the RBSauto reboot or the front LED come on as I did the other nite.
Seems that a power OFF or complete pull of the power adapters for a period of time after the factory reset seems to have cleared the bad state that the RBR and RBS were in. The system seems to be running well now in AP mode, I'll montior this for next few days to see if anything re-appears.
Anyone seeing this odd behavior, Reset or not, pull the power adapters for at least 1 minute then plug back in as one additional step.
- FURRYe38Sep 02, 2021Guru - Experienced User
Speed testing with a wireless mac book pro connected to one of the RBS i'm near is pretty good too. RBR is set for 25% power output as well:
- FarmerBob1Sep 02, 2021Luminary
Sounds like a good reason for a 30-30-30 Reset.
Also I just happen to stumble on this:
How often should you reboot your router . . .
Shouldn't need to reboot routers every so often, if thats the case, there maybe other problems.
I'm curious why the reset didn't work well...
- FURRYe38Sep 04, 2021Guru - Experienced User
Well updating this post. After the reset then leaving the system powered off then caming back to it the next day and setting up in AP mode, has been stable since. Have not seen any RBS issues or reboots. I presume a full power OFF, maybe 5 minutes max should be tried for those of you seen odd RBS rebooting or sync issues on v4. This information was sent over to NG for review.
Good Luck.
- bullm00nSep 10, 2021Virtuoso
FURRYe38 wrote:Well updating this post. After the reset then leaving the system powered off then caming back to it the next day and setting up in AP mode, has been stable since. Have not seen any RBS issues or reboots. I presume a full power OFF, maybe 5 minutes max should be tried for those of you seen odd RBS rebooting or sync issues on v4. This information was sent over to NG for review.
Good Luck.
Two Qs:- "The Erase Button on the RBR" - where is that?
- re: Connecting the the RBS Web Page and getting the connection error. This is still happening for me, on the beta and previous release - I have not upgraded to this latest version yet, but will this weekend. I notice it seems to only happen if I access the Connected Devices page. I have not done that in several days and the Status page still loads and works fine. Have you not seen that issue?
Thanks,
Steve
- FURRYe38Sep 10, 2021Guru - Experienced User
bullm00n wrote:
Good Luck.
Advanced tab/Administration/Backup.
- re: Connecting the the RBS Web Page and getting the connection error. This is still happening for me, on the beta and previous release - I have not upgraded to this latest version yet, but will this weekend. I notice it seems to only happen if I access the Connected Devices page. I have not done that in several days and the Status page still loads and works fine. Have you not seen that issue? I have not. I use MS Edge and Opera GX browsers when working with the RBRs web page. I just did a ERASE (factory reset) last week and after leaving the RBR and RBS OFF for 24 hours and back ON, system has been solid on v9 FW. Mines in AP Mode currently. v16 is being offered and will be loading this up this weekend.
- FURRYe38Sep 13, 2021Guru - Experienced User
So updated my 8 series in AP mode to v16 beta last Friday manually. After loading FW and system was back online. I powered everything OFF for a few minutes then back ON with the RBR first then RBS. No Factory Resets. All is working and stable in AP mode.
