Xmk123
Aug 30, 2021Tutor
RBR850/RBS850 4.6.3.9 Firmware problem
RBR850 in AP mode After updating to 4.6.3.9 (rbr850 and rbs850 s) lost CONNECTION (wireless) to my two satellites (RBS850). Tried wired (backbone), works. Switched to router mode all fine (wireless a...
- Aug 30, 2021And xcelebric on this forum
FarmerBob1
Sep 16, 2021Luminary
So getting things back to a working point in .223 and leaving it, I see what happens when you don't keep an eye on things. You get violated. After I wrote a huge post that was half disgust, half humor and posted it. It did post. Come to find out the issue that I was posting about was when the RBK system was being force fed v4.6.3.16_2.0.51. That just added to my post not posting. But then it would have been wrong. I would have been writing about a supposed full self-shutdown and it wasn't. It was the update. I was trying so hard to stay in .223 until a rev came out that was halfway stable. That's what I get for trying.
Although things have been as well as it was in .223. Even with the forced update which is a "Dirty Update". Now with that said, I jinxed myself and everything will fail monumentally this afternoon. It won't matter much except it'll cut off Amazon Music Ultra from the Mothership and I won't have music while I trim back 225 feet of 6' high Evergreen bushes. Yup, we're goin' full party mode in the South 40 today. Hopefully that will calm me down enough that when the RBR fails it doesn't end up in the 40' dumpster my neighbor parked along the party yard bushes.
Sep 16, 2021Guru - Experienced User
Factory reset the RBR and RBS. when you see the front pulsating WHITE, Power OFF for 2 minutes on the RBR and RBS. Leave the RBS OFF. Walk thru the setup wizard on the RBR. If you see odd issues.
