SparRiot
Sep 29, 2021Aspirant
RBR850/RBS850 constant Internet disconnect on V4.6.3.16_2.0.51
RBR850 / RBS850 FW: V4.6.3.16_2.0.51 Getting Internet disconnects several times a day since upgrading firmware upgrade from 3.2.16.x. Now on latest and behavior remains. - Been through more th...
- Oct 13, 2021
Problem solved.
Switched to AP Mode and running through an Untangle firewall. It gives me much more control and logs everything to a local syslog instance. I'm also out of forced and poorly tested firmware updates.
SparRiot
GPON ONT
Model: FOG421
I have never looked at the light as its just out of sight on the shelf beside me. I know its a disconnect because I get booted from VPN and RBR850 log looks like this:
[DHCP IP: (192.168.1.7)] to MAC address AB:CD:EF:01:23:45, Thursday, Sep 23,2021 21:29:01
[DHCP IP: (192.168.1.13)] to MAC address AB:CD:EF:01:23:46, Thursday, Sep 23,2021 21:28:59
[Time synchronized with NTP server] Thursday, Sep 23,2021 21:06:41
[Internet connected] IP address: 47.177.112.123, Thursday, Sep 23,2021 21:06:17
[Internet disconnected] Thursday, Sep 23,2021 21:06:16
[DHCP IP: (192.168.1.4)] to MAC address AB:CD:EF:01:23:47, Thursday, Sep 23,2021 21:05:32
One more bit of information is that I ran the Frontier router and wireless for several days a week or so ago to eliminiate the network connection. It was rock solid the entire time.
Sep 29, 2021Guru - Experienced User
If this was happening before the FW update and on prior versions of FW, possible this is a ISP and ONT issue.
Seeing it disconnect then reconnect like that mean the RBR lost the connection to the ONT or the ONT lost it's service to the ISP signal. Something to have the ISP check and ask them to check there logs for your line to see if they see any of these disconnections in there logs for your line.
Be sure your using good quality LAN cable between the ONT and RBR. CAT6 is recommended.
Please do not post MAC or public WAN side IP addresses in public forums.
- SparRiotSep 29, 2021Aspirant
This all start after update to 3.2.18.
I did have chat with Frontier who tells me ONT connections were solid. They won't troublehsoot router issues for Orbi. As mentioned, switched to Frontier router for 4 days and there were no issues.
Thanks for mentioned the MAC/IP addresses. MAC addresses & public IP addresses are all fake in the post.
