SparRiot
Sep 29, 2021Aspirant
RBR850/RBS850 constant Internet disconnect on V4.6.3.16_2.0.51
RBR850 / RBS850 FW: V4.6.3.16_2.0.51 Getting Internet disconnects several times a day since upgrading firmware upgrade from 3.2.16.x. Now on latest and behavior remains. - Been through more th...
- Oct 13, 2021
Problem solved.
Switched to AP Mode and running through an Untangle firewall. It gives me much more control and logs everything to a local syslog instance. I'm also out of forced and poorly tested firmware updates.
SparRiot
Oct 13, 2021Aspirant
Problem solved.
Oct 13, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
