ENedo
Apr 10, 2022Aspirant
RBR850/RBS850 issues after upgrading to v4.6.7.13
Looking for assistance downgrading firmware to previous version. Updating router and satellite to 4.6.7.13 has caused significant issues with frequent full network drops. Have gone through basic tr...
ENedo
Netgear CM700
Approximately 4,000 sq ft
RBS is 28’ from RBR. One floor up on opposite side of house. Blue connection prior to firmware update (still blue now) and no issue with RBS. Problem seems to be full outage as devices on both RBR and RBS lose connection.
What channels are you using? Auto? Try Auto and 48 on 5Ghz.
Running this on previous firmware and current firmware.
Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Tested for full day, no change.
Neighbors on both sides separated by approximately 2 acres each. No issues previously.
Armor, Circle, Traffic Meter.
Have tested multiple versions including all off, no change.
Turn off AX for 2.4 CTS set to 2347.
Tested for full day. No change.
Netgear CM700
ENedo
Issues occur both with the rbs in use and w/o
