PneuMol74
Dec 29, 2022Aspirant
RBR850/RBS850 LAN connections not visible
Hi experts, I implemented an Orbi network some months ago which contains a #RBR850 and 2 satellites (one #RBS850 and one #RBS750). Now I had to change some of their locations within our house to get...
CrimpOn
Dec 29, 2022Guru - Experienced User
I thought the Hue hub just has two physical connections: ethernet and power. It cannot be moved?
PneuMol74
You're right, it's just these 2 connections. The challenge is not the connection, it's the physical installation behind the closet with fixed cabling. And trust me the effort would be huge... đ
