JaccoG
Nov 26, 2023Aspirant
RBR850/RBS850 stops communicating at LAN side
Since a couple of weeks, my Router (RBR850) and all connected satellites stop communicating to all LAN connected devices (either wired or wireless). There is no network traffic possible, even the wir...
JaccoG
Nov 27, 2023Aspirant
Hi Furry,
Thank you for the response.
I will do a factory reset later this week and see if that helps.
Nov 27, 2023Guru - Experienced User
I recommend when you do, use a wired PC and web browser to FR and setup the system from scratch.
Try the following process:
Factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
